Hiring is one of the hardest jobs out there. Recruiters need to deal with fake credentials, fake resumes, and more. As a result, recruiters spend most of their time shortlisting candidates rather than reaching the hiring stage.
To solve this issue, we have plenty of tools. Among them, Endorsed stands out. It is an AI-driven tool that helps with automated resume screening, reduces human bias, and more.
However, if you haven’t heard of the tool before, then in this post we are going to walk you through the benefits of Endorsed and help you understand if it’s good enough.
What’s Endorsed?
Endorsed is an AI-powered hiring platform designed to help companies identify the right candidate by making the whole process faster and more accurate. It doesn’t limit itself to just AI-powered resume screening to verify candidate information, but also generates clear application summaries, reduces bias, and assesses alignment with company values.
It also integrates with any of your existing ATS systems, so you can simply connect the tool to your existing system without needing to overhaul your current recruitment process.
Key Features of Endorsed
Fraud-proof verification
Endorsed offers a built-in verification system that automatically detects fake credentials and identifies mismatches and misrepresented experiences, which can be highly valuable for remote or high-volume hiring. Manual verification can be slow and often unreliable. By flagging inconsistencies early, the platform helps companies avoid bad hires and reduces the risk of fraud.
AI-written candidate summaries
Instead of manually scanning resumes, you can get an AI-generated summary of each application. The summary highlights key information such as relevant skills, experience, and role fit. As a result, you can quickly review each candidate and decide whether to proceed or not.
Bias reduction technology
Endorsed uses algorithms designed to minimize unconscious bias during candidate evaluation. It shifts focus from superficial resume signals to verified skills, experience, and alignment. As a result, the platform helps make fairer hiring decisions and improves diversity outcomes without lowering hiring standards.
Values alignment matching
Apart from skills and experience, Endorsed also checks how well a candidate aligns with your company’s culture and core values. This value-based matching helps teams identify candidates who are more likely to perform well long term, reducing attrition and improving overall quality of hire.
Quick talent identification
Endorsed rapidly surfaces top candidates from large applicant pools by prioritizing verified qualifications, relevance, and fit. As a result, companies can focus on high-potential candidates instead of spending time filtering unqualified or misleading applications.
Streamlined recruitment process
Endorsed supports an end-to-end recruitment workflow, from initial screening to candidate engagement. By automating repetitive tasks and centralizing insights, it reduces time-to-hire and simplifies coordination between recruiters, hiring managers, and stakeholders.
Easy integration
It is designed to integrate seamlessly with existing ATS or recruitment software. Teams can embed AI screening and verification capabilities with minimal code, without replacing existing systems or disrupting established workflows.
Candidate engagement tools
Endorsed ensures that every candidate interaction is structured, relevant, and aligned with business needs. Even candidates who are not selected receive more meaningful engagement, which helps protect employer brand and maintain efficiency in the hiring process.
Use cases of Endorsed
- High-volume hiring: Endorsed is the perfect solution for companies that attract hundreds or thousands of applications, as it cuts down the manual resume screening process. Plus, the platform on its own quickly verifies candidates, generates summaries, and surfaces the most relevant profiles.
- Quality-focused recruitment: For companies that prioritize long-term performance over speed alone, Endorsed shifts evaluation away from resume design and keyword tricks. Hence, candidates are assessed based on verified skills, experience, and cultural alignment.
- Fraud prevention: Remote hiring can be risky due to fake credentials. However, Endorsed detects fraud or inconsistencies early in the hiring process and helps prevent bad hiring.
- Diversity and inclusion initiatives: Endorsed supports diversity-focused hiring by reducing unconscious bias in candidate evaluation. By standardizing assessments and focusing on objective signals, the platform helps organizations build more diverse teams while maintaining high hiring standards.
- Values-based hiring: Apart from technical skills, it also judges how well a candidate aligns with a company’s mission, culture, and values.
- ATS enhancement: Endorsed enhances your existing ATS platform by acting as a layer. You can add AI-driven screening, verification, and insights without needing to replace existing systems.
- Remote hiring: If in-person interviews aren’t possible, Endorsed helps verify candidates and assess fit digitally. This makes it easier for distributed teams to hire with confidence, even across geographies and time zones.
- Startup scaling: Startups can also use Endorsed to scale hiring quickly without compromising on quality or culture, as it allows them to make better hiring decisions while growing fast and reduces the risk of early-stage mis-hires.
Endorsed pricing
Talking about the pricing of Endorsed, it has a standard Pro plan costing $299 per month. The plan offers one recruiter seat, three active jobs, AI applicant review, AI application review, fraud detection, sourcing, and more.
However, if you want additional features, it offers two different custom plans, Growth and Enterprise. These plans have the same features as the Pro plan with enhanced limits.
Also, both the Pro and Growth plans include a 14-day trial period, so you will have plenty of time to understand and use the tool.
Real-world impact
In real-world hiring scenarios, Endorsed helps teams improve their hiring processes through AI-powered screening and summaries. It quickly identifies top candidates early, reduces unnecessary interviews, and keeps recruitment workflows focused. By standardizing evaluation and emphasizing verified skills and values alignment, companies report more consistent hiring outcomes and better alignment between candidates and business needs.
When it comes to performance, organizations can save significant time per candidate by eliminating manual resume reviews and redundant verification steps. Also, through fraud detection, it helps prevent companies from hiring the wrong employee.
