Have you gone fed up managing your discrete pictures? Are you looking forward to buying a perfect photo organizer or photo editor for managing your different photos effectively? If yes, here we are with the perfect software for you, and that is ON1 Photo Raw 2022.
ON1 Photo Raw 2022 Review
Managing photos effectively has no longer remained a hectic task now. ON1 Photo Raw 2022 is one of the marketplace’s ultimate photo organizer and photo editor tools. It is designed to fulfill the growing demands of photographers and videographers effectively. It is one of the best tools that help you achieve professional results while keeping your workflow simple, powerful, and efficient.
This tool has served as a game-changer option in the league. It is the best lightroom alternative that comes up with powerful photoshop features. It offers layer integration that makes creating a multi-layered photo or composite photo easier while keeping the non-destructive settings perfectly placed for each image. The tool is quite efficient in managing all of the photo editing tasks under a single flow.
Key Features of this photo editing software for Windows
ON1 Photo Raw 2022 is a features-loaded photo managing and photo editing tool that makes it easier for users to enable absolute performance using different features. The tool comes up with a wide range of features such as:
- One can easily resize the images here using the perfect resize option.
- Users are free to add photographic effects using PhotoTools here.
- Users can easily create an album layout along with PhotoFrame.
- It offers users the freedom of adding layers to the lightroom and the aperture with perfect layers.
- It is the tool that corrects your photos perfectly with the help of PhotoTune.
- Users here can easily create beautiful bokeh with FocalPoint.
- One can easily opt for the Mask Pro option to remove unwanted backgrounds effectively.
- Different individual products here work as plug-ins and on their own, making things even more convenient.
Use cases of Features
Here are the two most common use cases of its features.
Sky Swap AI
- Add an image that has Sky along with other objects for a better reveal
- Click on the View icon on the side menu, and then click on the Sky section under Layers
- Tap on the Sky Swap option to open up the Sky AI
- Here you can select
- Category (Cloud, Dramatic, Night, Storm)
- Sky type (Select the preferable mode from Night, Storm Clouds, Sunset, Dramatic, and more, and replace the plain sky with any of these.)
- Once done, the filter will start processing immediately and create a sky mask.
- Tap your mask thumbnail at the top of the sky panel and bring up the mask controls.
- Modify the sky as per your preferences.
- Change the appearance of your sky as per your choice.
- Adjust the lighting and reflection option from Foreground.
- Use the standard copy feature from the mask panel and combine it with an invert to select foregrounds for making edits on another layer.
Time Lapse
- Tap on the Browse icon and then navigate to the select the images section.
- Add contrast and saturation to your taste, and once done, go to the Settings menu option.
- Select Sync Settings for copying the changes to all of the selected photos.
- Make a right-click on the selected photos and then choose the Create button to go further.
- Go to the File menu option and select the Time Lapse section.
- Once done, the time-lapse will open up, providing all options in the compact and option-filled dialog.
- Make the settings as per your preferences, and once done, process the same in the background.
- Name the video for the most selected photo at the time of creation and place it besides in your Browser window.
Why is ON1 Photo Raw 2022 the best yet most affordable photo editor?
ON1 Photo Raw 2022 is supposed to be one of the best and most affordable photo management and editing options due to the presence of a vast range of features. It is one of the best and most complete applications with an intuitive user interface that makes it easier for the users to get complete control over the digital images. One can now easily manipulate the digitals without any issues. It is a powerful application that comes up with a wide range of enhancements and different other powerful tools that further process the RAW.
ON1 Photo Raw 2022 is designed to support output from the different high-end cameras and supports the different types of graphics formats. Users here are free to edit and customize the various aspects of the images without any issues. It gives photographers the ultimate image quality with the state-of-the-art raw processing engine, superior noise reduction with NoNoise AI, incredible filters and presets in Effects, automated portrait retouching tools, and now the best photo enlargement software, ON1 Resize AI, fully integrated
The tool ensures users have quick access and also doesn’t have a significant impact on your pocket. It is one of the most affordable tools, with one-time pricing of about $99.99. Moreover, one can also opt for the subscription packages here at just the cost of $7.99 per month. Consistent updates, 200GB of cloud syncing storage, and much more make it the best option in the league.
