Handling Outlook’s data files can become a hassle when the PST or OST files are corrupted, mailboxes become large and refuse to open, or you forget the passwords of your PST files. This is where the Stellar Toolkit for Outlook becomes a valuable tool, offering a comprehensive solution to repair, manage, and organize your Outlook data. This article outlines a detailed review of Stellar Toolkit for Outlook, the best Outlook repair and recovery tool.
Stellar Toolkit for Outlook review
Stellar Toolkit for Outlook is the best Outlook recovery and repair tool for the Outlook desktop app. Whether you need to repair a Corrupted PST file, convert OST to PST, split or merge mailboxes, or recover lost PST files’ passwords, this tool makes the process easy and stress-free for you.
Common Outlook issues that lead to data loss or corruption
Outlook users often face unexpected issues that lead to data loss or corruption. The following are the possible scenarios:
- Outlook PST or OST file corruption due to improper shutdowns, virus attacks, large file size, etc.
- Difficulty in accessing emails because of damaged mailbox files.
- Accidental deletion of important emails.
- The risk of large Outlook PST files that exceed Outlook storage limits.
- Forgotten or lost PST file passwords.
- Challenges while merging or splitting Outlook data files manually.
Overview of Stellar Toolkit for Outlook
Stellar Toolkit for Outlook is a complete suite designed to simplify the management, repair, and recovery of Outlook data files. It comes with seven powerful tools that cater to various needs. With Stellar Toolkit for Outlook, you can do the following:
- Repair mailbox
- Convert OST to PST
- Split Outlook PST file
- Merge mailboxes
- Recover deleted emails
- Compact Outlook PST files
- Recover Outlook PST file password
System Configuration
To install and run Stellar Toolkit for Outlook on your system, it should fulfill the following hardware requirements:
- Processor: Intel and AMD compatible (x64-based processor)
- Memory: Minimum 4 GB of RAM (8 GB recommended)
- Hard Disk: Minimum 250 MB of free space for installation files
- Operating System (64-bit only): Windows 11, 10, 8.1, 8
This software is compatible with Microsoft Office 365, 2021, 2019, 2016, 2013, 2010, and 2007.
Installation and User Interface
First, visit the official website and click the Free Download button to download the software. Once the download is complete, double-click the installer file. Click Next and change the default installation location by clicking on the Browse button. Or, you can leave the installation location as it is. Once the installation is finished, click Launch to launch the software.
The Stellar Toolkit for Outlook has a clean user interface. All the tools are easily accessible.
Key features of Stellar Toolkit for Outlook
Let’s see the features of Stellar Toolkit for Outlook.
- Repair corrupt Outlook data files: Stellar Toolkit for Outlook lets you repair corrupted Outlook data files. These data files include both PST and OST files. Outlook data file corruption can lead to several errors, including Outlook crashes on startup and sending or receiving email failures. You cannot use Outlook properly until you repair the corrupted data file.
- Outlook data file conversion: With this software, you can convert OST to PST files.
- Splitting Outlook PST files: You can split larger PST files into smaller ones.
- Merge the mailboxes: This is an amazing feature of this software that lets you merge mailboxes from different email accounts and email clients into a single PST file.
- Recover deleted emails: If you accidentally delete some important emails, never mind. You can recover them with Stellar Toolkit for Outlook.
- Compress Outlook PST files: Large Outlook PST files are difficult to manage. You can compress them easily with the help of this software.
- Recover Outlook password: Outlook allows us to protect the PST files with a password. If you forget your password, you cannot open that file in Outlook. The password recovery feature allows you to recover the lost password.
Utilities of Stellar Toolkit for Outlook
The Stellar Toolkit for Outlook includes seven powerful tools and utilities. Let’s see each of them.
1] Repair Mailbox
The Repair Mailbox utility allows you to repair the corrupt Outlook data files (PST and OST). If you encounter issues with Outlook due to a corrupt data file, you can use this utility to repair the data file.
Here is how to use it:
- Launch the software and click Repair Mailbox.
- A new interface will open asking you to select the corrupt data file.
- Click Browse and select the corrupt data file.
- Click Repair.
2] Convert OST to PST
With this utility, you can convert OST to a PST file. The batch file conversion feature is also available to save time. Using this utility is easy. Click Convert OST to PST. Now, you can select the Outlook OST file manually or use the Profile List option to detect the available Outlook profiles on your system automatically.
After selecting the OST file, click Convert. After converting the file, you can save it as a PST. Alternatively, you can use other available options, such as exporting it to the existing Outlook profile or exporting it to Microsoft 365.
3] Merge Mailboxes
This is a very useful utility. Using it, you can merge the mailboxes from different email clients and different emails into a single PST file. This makes it easy for you to read all emails.
To use it, click Merge Mailboxes. A new interface will appear. Click Select Mailboxes. Now, you will have the following options:
- Offline Mailbox
- Online Mailbox
- Identity folder
The Offline Mailbox is used to merge PST, NFS, or DBX offline mailboxes. The Online Mailbox option is used to merge mailboxes from various email clients, such as Microsoft 365, Gmail, Yahoo, and others. The last one is used to merge mailboxes from less popular email clients, such as Spicebird and Thunderbird. You can also select the date range to merge emails.
After merging the mailboxes, save the PST file on your PC. When you open it in Outlook, you will have a separate Personal Folders section in Outlook containing all the merged mailboxes.
4] Recover Deleted Emails
With this tool, you can recover the deleted emails in Outlook. You can save the recovered emails as PST, RTF, HTML, PDF files, and more.
5] Recover Outlook Password
This is another important utility. If you forget the password of your Outlook PST file, you can easily recover it with the help of this utility. Select Recover Outlook Password. A new interface will open. Now, drag and drop the PST file. It will start scanning the PST file and show you a list of some passwords. All of these passwords will work with the PST file. Enter any of these passwords to open the PST file. After that, you can change the password.
6] Split and Compact Outlook PST file
These tools allow you to split and compress the Outlook PST file, respectively.
Performance and Speed of Stellar Toolkit for Outlook
The performance and speed of Stellar Toolkit for Outlook are impressive, delivering efficient results in handling Outlook data files.
Stellar Toolkit for Outlook Pricing and Licensing
You can purchase Stellar Toolkit for Outlook at reasonable rates. Visit its official website for more details about the pricing structure. You will get instant delivery through email. Stellar also provides free 24/7 technical support to premium users.
In the Demo version, users can check the preview of the entire PST data.
Pros and Cons of Stellar Toolkit for Outlook
Stellar Toolkit for Outlook is a useful software. Let’s see its advantages and disadvantages.
Pros
- Seven useful tools are available in the single software suite.
- You can easily merge mailboxes from different email accounts and email clients.
- It also helps you recover deleted emails from your Outlook account.
- If your PST or OST file is corrupted, you can repair it with a single click.
Cons
I did not find any major limitations in this software. However, the Online Mailbox option of the Merge Mailboxes feature did not work well for me. I was getting a connection error every time.
Conclusion
After thoroughly testing Stellar Toolkit for Outlook, it’s clear that this is more than just an Outlook repair tool – it’s a full-featured solution for anyone dealing with PST/OST file issues. Whether you’re an individual Outlook user trying to recover emails, an IT admin managing user mailboxes, or a Managed Service Provider (MSP) supporting clients, this toolkit delivers real, practical value.
The 7 integrated tools effectively address common and complex Outlook problems – from corrupted files to password recovery and mailbox conversion – all through a clean, intuitive interface and fast processing.
Verdict
I give it 4.5/5. Highly recommended for anyone who regularly works with Outlook data and wants a reliable, all-in-one solution.
Overall
Functionality & UI
(4.5)
Performance
(4.5)
Output Quality
(4.5)
Security & Privacy
(4.5)
