When a disaster happens, like a failed RAID system, a damaged NAS, or a missing virtual machine, recovering data can be stressful. Important files disappear in seconds, leaving you worried about data loss. In some cases, normal data recovery tools fail to recover data, especially when dealing with complex data storage systems, such as RAID. The Stellar Toolkit for Data Recovery is a powerful tool designed to recover your data, even in complex data loss situations. This article reviews Stellar Data Recovery software.
Stellar Toolkit for Data Recovery: Advanced Data Recovery made simple
The Stellar Toolkit for Data Recovery is a solution for advanced data recovery, designed for both IT professionals and everyday users. Data recovery is a complex process, especially when dealing with advanced storage systems. Stellar Data Recovery software is a lifesaver for complex data loss situations, whether NAS data recovery, RAID data recovery, or virtual drive recovery.
Advantages and key features of Stellar Toolkit for Data Recovery
Stellar Data Recovery software offers several key features that simplify the data recovery process.
Effortless Data Recovery for the complex RAID systems
RAID storage systems are more complex than normal storage systems. That’s why RAID data recovery is the most challenging process. RAID systems are built for high performance, but their failure results in severe consequences. Multiple causes can result in the malfunctioning of RAID systems, such as disk errors, accidental configurations, etc. Malfunctioning of RAID systems makes your RAID volumes inaccessible.
The following points best explain why Stellar Toolkit can be your best software for advanced data recovery.
- Automatic RAID reconstruction: It can automatically reconstruct the RAID array even if you do not know the RAID parameters, such as disk order or stripe size. It intelligently analyzes your RAID drives and suggests the probable configurations.
- Virtual RAID creation: If the physical reconstruction is not possible due to drive damage, it creates a virtual RAID so you can scan it and recover data.
- RAW recovery: In the worst-case scenarios, where the file system is severely damaged, it performs a file signature-based search on RAID images to recover your data.
- Supports RAID 0, 1, 5, 6, 10, and SHR: Stellar Data Recovery software supports multiple RAID configurations, including RAID 0, 1, 5, 6, 10, and SHR.
With Stellar, you do not need a RAID expert for data recovery. The software guides you through the process, making advanced data recovery reliable. This is what makes Stelolar Data Recovery software a game-changer.
NAS data recovery
The Network Attached Storage (NAS) devices are the backbone of many small-scale businesses and home offices. But when they fail, especially in a RAID setup, the data recovery process can become a challenging task. The Stellar Toolkit makes the NAS data recovery process simpler.
The following features make Stellar the best toolkit for NAS data recovery:
- Direct NAS RAID support: Stellar Toolkit allows you to recover data from major NAS devices like Synology, QNAP, and ASUSTOR drives formatted in different file systems, like BTRFS.
- Handles controllers and disk failures: Whether the data loss occurs due to controller failure, disk errors, or system failures, Stellar Toolkit helps you recover your data from the affected NAD RAID.
- Restores all file types: Stellar Toolkit can restore any file from your affected NAS.
With Stellar Toolkit, you do not need a specialized tool for NAS data recovery. Its support for Synology and BTRFS makes it the best software for modern NAS environments.
Virtual drive recovery
Today, Virtual Machines are used in most IT industries. We can install a different operating system on a Virtual Machine. When a virtual disk becomes corrupted, you have a risk of losing the entire operating system and its contents. The Virtual Drive Recovery feature of Stellar Data Recovery software provides you with the following benefits:
- Mounts VM images: It supports multiple formats, including VMDK (VMware), VDI (VirtualBox), and VHD/VHDX (Hyper-V).
- Find lost partitions: It can restore deleted or lost partitions inside virtual machines.
- Multi-platform support: Stellar can recover data from virtual drives installed on different platforms, including Windows, Mac, and Linux.
All-in-one data recovery
Stellar Data Recovery software is not limited to NAS, RAID, and virtual drive data recovery. It has many additional features that help you in every data loss situation.
- Multi-storage media support: Stellar software supports different storage devices, including HDDs, SSDs, USB flash drives, SD cards, Optical cards, and more.
- Data recovery on encrypted drives: Recovering data from an encrypted hard drive is the most challenging task. Stellar software eliminates this limitation. It can recover data from BitLocker-encrypted hard drives (with password or key).
- Partition recovery: Stellar data recovery software can find and recover lost or deleted partitions, even on formatted or corrupted hard drives.
- Bootable recovery media: With Stellar, you can create a bootable USB to recover data from unbootable systems.
- Multi-file system compatibility: It works with different file systems, including NTFS, FAT, exFAT, APFS, HFS, HFS+, EXT2/3/4, and BTRFS file systems.
- Preview before recovery: It shows you a preview of your files before starting the data recovery process.
- Resume recovery: Usually, the recovery process takes a longer time. Stellar Toolkit allows you to pause the recovery process and resume it later.
- Create an image: You can also create a recovery image of a hard drive partition.
Real-world testing: Features that impressed me
- User-friendly interface: Stellar Toolkit for Data Recovery has a clean and simple user interface. Even the advanced RAID data recovery tasks are presented in a step-by-step wizard.
- Deep scan: Stellar data recovery software offers a deep scan feature that helps you recover data from severely damaged drives, where most data recovery software fails.
- Batch data recovery: A corrupted drive usually has multiple files, folders, and partitions.
- Repair tools: It can also repair corrupted files, like videos, images, etc.
Reasons why Stellar Toolkit is the best choice for data recovery
The following points explain why it is the best choice for advanced data recovery:
- Versatility: It is an all-in-one toolkit that handles data recovery from multiple storage systems, including RAID, NAS, VMs, encrypted drives, and more.
- Reliability: Stellar is a renowned name for data recovery. It is trusted by millions worldwide and has a good track record in professional environments.
- No guesswork: Intelligent algorithms help you recover data in complex scenarios, even if you do not know your RAID parameters and partition details.
- Preview before data recovery: After scanning your drive, it shows you a preview of your data before starting the data recovery process.
Data loss can affect anyone and happen anytime, no matter whether you are managing official or personal data. The Stellar Toolkit for Data Recovery delivers a powerful and versatile solution for RAID data recovery, NAS data recovery, and virtual drive recovery. In addition to that, it is packed with a bunch of features that help you recover data in every situation, from encrypted drives to unbootable systems.
Download the free trial today and scan your drives to preview your lost data. See why it is the most trusted software for data recovery among professionals and everyday users.
